OK, Changed my window motor, now have a slight bang. Please help with any suggestion
As it says changed my window motor with one I bought from Advanced Auto.
Now when the motor is engaged going from fully open to closed there is a slight bang at first then the door panel pulls in about a 1/4". This stays this way until the window is fully open, then the panel comes back into place.
What did I screw up??
I have no clue but off the top of my head it sounds like it's just not bolted down all the way. Have you taken it apart and watch it while you are moving it up and down. If not do that and see what looks to be your problem.
My window has had slop in it since I replaced the motor. I haven't looked at it, but I think either the motor mount bolts are loose, or the rivets that hold the glass to the frame are worn out.
- Brent
- Brent
