Ok problem while checking my valvtrain geometry
Old 04-12-2008, 04:27 PM
  #16
Moderator
rskrause's Avatar
Lookin good.
Rich
rskrause is offline
Old 04-12-2008, 06:36 PM
  #17
Dave1980's Avatar
Originally Posted by rskrause
Lookin good.
Rich
Ok thanks Rich, and others . I just measured the trickflow adj. pushrod out with a digital 8" caliper and got 7.031. I measured it from tip to tip while staying centered on the pushrod. I looked over this page some http://www.compcams.com/Technical/FA...nGeometry2.asp. The theoretical length is pretending that the oil hole would not have a flat spot in it right? So I guess you can say I measured out actual length according to that site.
Dave1980 is offline
Old 04-12-2008, 07:38 PM
  #18
mdacton's Avatar
Originally Posted by Dave1980
ok here is the update I think i am centered here dont you think?
looks alot better.
mdacton is offline
Old 04-12-2008, 10:17 PM
  #19
BigBadBlack93Z's Avatar
what changes did you make that require 1/8" shorter pushrods? Just curious.
BigBadBlack93Z is offline
Old 04-12-2008, 10:55 PM
  #20
Dave1980's Avatar
I had the block 0 decked, and used LE3 heads that are milled some along with a 1074 gasket. (also used ls7 lifters BTW, which might have a different cup depth)
Dave1980 is offline
Red97LT1
9
12-17-2014 06:13 PM
danielbmx
08-27-2002 11:11 PM
johnsocal
21
08-17-2002 01:06 AM
SilverWS6
13
08-14-2002 09:29 PM
newby
10
07-27-2002 11:39 AM
Quick Reply: Ok problem while checking my valvtrain geometry
