Is it ok to use steel header bolts?
Old 02-02-2008, 07:48 AM
ssbowtie1's Avatar
I found a set of bolts from Mcmaster that would work well for headers and are cheap (~8 + s/h for a pack of 25). The only thing is that they are steel. I've heard that using steel screws in aluminum sometimes cause corrosion problems. Do people use just steel bolts or do they have to be of another material to work in our alum heads?
ssbowtie1 is offline
Old 02-02-2008, 08:50 AM
joeSS97's Avatar
The only problem is that the heads of the bolts will rust very fast.Get some stainless bolts...The threads get a good coat of anti-sieze so that isnt a problem.
joeSS97 is offline
Old 02-02-2008, 10:47 AM
ssbowtie1's Avatar
I just called my local hardware supplier and they have stainless steel allen head bolts. Has anyone used allen head bolts for their headers? Seems like it would make installation a breeze.
Old 02-02-2008, 11:46 AM
speed_demon24's Avatar
Make sure you get grade 8. I would just spend the $35 on ARP's if it was me.
speed_demon24 is offline
Old 02-02-2008, 01:14 PM
Pontiac_97's Avatar
never used steel so idk. i just bought some ARP 3/8 bolts from summit. $20 bucks for 12. its not that hard to put the bolts in anyways.
Pontiac_97 is offline
Old 02-02-2008, 01:26 PM
2000GTP's Avatar
They are going to rust, that is about it. I am using steel bolts, nothing pretty to look at when they are rusted alongside coated headers. At least if you went stainless, they won't rust and if you took it a step further and got the locking version, you wouldn't have to worry about them backing out either.
2000GTP is offline
Old 02-02-2008, 02:33 PM
ssbowtie1's Avatar
Why do the bolts have to be grade 8? They're just header bolts.
Old 02-02-2008, 06:02 PM
BTC
BTC's Avatar
Location: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
There are some stainless Breslin bolts floating around on EBay if you're interested, but they aren't cheap.
BTC is offline
Old 02-02-2008, 06:24 PM
1989TransAm's Avatar
Here is a link to some of the Breslin style header bolts. I have found I like this style the best.
http://www.route66supply.com/store/page53.html
1989TransAm is offline
Old 02-05-2008, 11:55 AM
ssbowtie1's Avatar
Just FYI...these are all out of stock.
Old 02-05-2008, 12:19 PM
BTC
BTC's Avatar
Search for Breslin on EBay. I think Boese Engineering has some of both the steel and stainless bolts if that's what you're interested in. I don't think the stainless bolts have Breslin in the tag line, so you would probably have to search their store to find them. They may only be available for big blocks, which means you'll get 16 bolts instead of 12. I would recommend the 1" bolts over the 3/4".
BTC is offline
Old 02-05-2008, 12:20 PM
ssbowtie1's Avatar
Yup that's what I did. Just wanted to let everyone know about the route 66 site so they don't waste time trying to get some from there.
I haven't decided if I want to spend ~85 shipped for the bolts, but I think I'm just going to do it. Its still ~50 more than arp stainless steel bolts but everyone praises them and I absolutely HATE header leaks!
Old 02-05-2008, 01:02 PM
truedualws6's Avatar
Percy's acquired Breslin a while back so check with them regarding availability.
Not cheap, but a nice product.
>>Percy's Split Lock Fasteners<<
truedualws6 is offline
Old 02-05-2008, 01:10 PM
ssbowtie1's Avatar
I just got a set of Breslins off ebay. 12 pack 1" long stainless steel for $65 shipped.
I cannot stand exhaust leaks and if this will give me a higher chance of having header bolts backing out, then I'm all for spending the extra 20 bucks.
A member here recommended soaking the felpro gaskets in warm water for 10 minutes prior to installation. He said he used this method and has not had any leaks in years.
Has anyone tried doing this?
Also, do you guys with Breslins use washers when installing the bolts?
Old 02-05-2008, 01:33 PM
BTC
BTC's Avatar
I didn't use washers. Who did you get the bolts from? Just out of curiosity, what was the part number?
BTC is offline
Quick Reply: Is it ok to use steel header bolts?
