Ok, what gives?? Electrical guys, step into my office.....
Old 09-25-2004 | 08:03 AM
Fastbird93's Avatar
Ok, trying to trace down my .080 Amp draw. I have the following disconnected, and just made another check:
Alternator
Everything at the main distribution block (behind the battery, all the cars cables, NOT the battery cable)
Starter
Essentially, NOTHING hooked up to the battery. And the draw is STILL there!!!! The main positive cable is hooked up still, and I'm setting the multimeter to Amps, in line with the negative terminal on the battery negative terminal, and with the positive terminal on the negative battery cable.
WTF would be doing this?
Old 09-25-2004 | 08:08 AM
Dave89IROC's Avatar
Re: Ok, what gives?? Electrical guys, step into my office.....
are there any fusable links coming off the starter?
Old 09-25-2004 | 08:16 AM
Fastbird93's Avatar
Disregard
Ok, I'm the winner of the dumba** of the day award. The ONE thing I thought it couldn't be, was. My MSD Digital 6. That's my draw. Everything I had seen had shown it hooked up with the positive cable directly to the battery. I pulled that cable with the multimeter hooked up and my draw went from .080 to .000 amps instantaneously.
So, another question. Will the Digital 6 work properly hooked up through a switched source (I.E. plugged into the fuse box like most end up with the electric WP)??
Old 09-25-2004 | 08:48 AM
Dave89IROC's Avatar
Re: Disregard
the heavy gauge(10 or 12) red wire should go strait to batt 12v, the smaller red(16g?) should be switched 12v
Old 09-25-2004 | 12:28 PM
Fastbird93's Avatar
Re: Disregard
Ok, I take it back again. I removed the MSD, and hooked everything up one wire at the distribution block at a time. The dual grey wire hookup was pulling about a .080 also. Funny thing is that a variety of items on each wire caused the problem, as I pulled all the associated fuses and tried one at a time by plugging it back in. Both wire circuits, a variety of fuses caused the draw. I hate electrical bugs.
And I'm also left wondering why the MSD would be pulling .082 amps when it's wired in correctly using the MSD harness.
DirtyDaveW
12-01-2016 05:37 PM
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
Lt1son
N2O Tech
11-25-2014 01:52 PM
Red97LT1
08-07-2002 05:45 PM
Quick Reply: Ok, what gives?? Electrical guys, step into my office.....
