okay I give up>>>
okay I give up>>>
how do you get the old U-joint out of the driveshaft....I've heated it (supposedly to weaken the injected nylon) put it in my vise as tight as I can....pryed on it, hammered it....I'm all out of options...how do you get the darn thing out????
did the nylon seep out? Cause you need to heat it up until it all seeps out. then hammer the **** out of it. I personally wnet and bought a mutipupose ball joint remover tool to press mine out. much easier....
what did you use to heat it up to the point that the nylon seeped out? I used a propane torch and it didn't budge! also, where to you get a "mulitpurpose ball joint remover" at???
95z_28_camaro_4_Ivan
10-03-2015 07:27 PM
09-18-2015 03:46 PM
