one more exhaust question
Has anyone every tried running thier exhaust like the "ricers" do to get the dual exhaust look. i would like to run true duals but i need the ground clearance because my driveway isn't the best. I was thinking a y after the axle and dual 3" in pipes with dual mufflers out back. right now i have stock manifolds - y pipe with a 3" catback....im not sure what it is but my car sound completely differnet from any other Z28 camaro i've ever heard.
thanks in advace
nightrida
thanks in advace
nightrida
Re: one more exhaust question
If you do a quick search, you'd find a ton of information on true duals. Truth be told, doing a true dual setup with stock manifolds isn't such a good idea, as the manifolds will be the choke of the system. Pick up a good set of long tubes and go from there. In the time being, the setup you have right now is plenty good.
thanks in advace
nightrida
thanks in advace
nightrida
I did see a Camaro with dual "fart cans" once.
TheGreenZ28
Exhaust System
12-06-2014 10:23 PM
