open loop tune?
open loop tune?
My car runs very good in open loop. Then when the rpms drop, and it goes into closed loop, it has a small miss, and just doesnt feel as fast. Ive been trying to fix this problem for over a month now after I got my pcmforless tune to no avail. I had it datalogged, sent it to bryan herter, he said I needed maf, got maf, problem still there. I am about to ask him to just tune it to run in open loop all the time. Thats when it runs the best. my question is has anyone else done this? What are the problems, or advantages?
Sounds like my problem. After it goes into closed loop , when you jab the pedal does it missfire and stumble, then pick up and rev fine? That is what mine has been doing for sometime now. I have searched this alot and from what I can tell it could be a number of things. Some say that the ICM gets heat soak and to gap it away from the head with some washers. Others say that is it a o2 sensor that is bad. Others say that it is a exhaust leak or vacume leak. LOL So it realy seems as though the problem would be best diagnosed with a scanner that reads live motor stats. Good luck man! Please post if you do track down and fix it
thanks. I have the same prob. camaro kid. Ive changed 02s, opti, coil, wires, fuel pump, maf, and it still does it. It started after my tune. I had it datalogged, and he said everything looked good, except the maf readings were very high, and my injectors were maxed at 5200 rpm. If this new tune doesnt help, then I will assume I have a leak at my header flange.
armedtrigger
02-24-2015 08:30 PM
Redbird
08-13-2002 03:29 PM
