Opinions on custom grind?
I have done a lot of research with different shops and companies about what cam to use emission legal in IL,
Here are the exact specs I am gonna go with.
Cam Spec Card
Engine: LT1/LT4
Part number: 07-000-8
Cam Grind Number: LT1 3196 / 3370 HR112
Gross Valve Lift w/1.5 .586 .571
Duration @ .006 Tappet Lift 287 303
Valve Timing @ .050 Lift 10 BTDC 46 ABDC
60 BBDC 8 ATDC
Installed @ 108.0 Intake Center Line
Duration @ .050 236 248
Lobe Lift .391 .381
Cam ground with 4* advance and 112 LSA
Cam Spec Card
Engine: LT1/LT4
60 BBDC 8 ATDC
Lobe Lift .391 .381
Thats HUGE!!! Thats some man ****. Definately NOT emissions friendly.
with 1.5's the lift comes out to 587/572
with 1.6's the lift comes out to 626/609
Any reason for the reverse split duration? What kind of heads are you running? Or is it a turbo set up?
Originally posted by 96YenkoClone
it is a custom cam for my setup
hey SVT no **** its obvious but i was answering the previous post's question, i was just seein if anyone ever ran anything like this before, so if you dont have any input just stay off the thread
58mm tb, 30# inj, fully ported lt1 heads 2.00/1.55, 1.52 rr, comp beehive springs 600 lift, 10.8:1 Speed Pro/Sealed Power Hyper pistons, scat 3.75 crank, rebuilt pm rods 5.7, shorty headers, no cats, 3" flowmaster, T56, 3.42
if you need anything else just let me know
That is a big cam for a 350 but in a 383 it is probably possible to tune it to the point where could squeak by the emissions test.
I'm not really familar with the IL emissions standards so I can't give you the best info.
You might try posting in the regional section. I guarantee that someone has used a similar cam and can give you a little help.
Sorry I couldn't be more help.
Also you can forget about those springs, or 1.6's for that matter, because you'll be on the edge of coil bind with damn near 590 lift with the 1.52's on a 600 lift spring. Get some better springs.
This doesn't seem like a very emissions friendly cam to me.
