Opinions on my options needed
Ok, knowing I need a new shortblock, and knowing that I'm on an approximate $3000 budget, what can I possibly look at??
Heads and all the rest are fine. ALL I need is your basic short block. No timing stuff, no lifters, maybe not even the pan, depending on application I go with.
That's what I'm starting to look at. Besides the rotating assembly, what else would I need??? I've not had to go through this yet and hadn't really given it much thought until now.
Basically, if I purchase a separate rotating assembly, I need a list of everything else I would need to complete the shortblock. No timing stuff needed, no lifters or valvetrain stuff needed. Just a list to complete the shortblock.
Also, will a 3.750 crank clear a stock oil pan??
It should. Not positive though, the tray might need clearancing. You should go with a deep canton pan anyway. You'd need ~400-500 of blockwork done. The rotating assemblies come with bearings and rings. You'd also want splayed 4 bolt mains. Block would need a bath, clean, bore/hone .030 over, and then labor to install everything.
After some hussled research:
I found a fully forged 383 shortblock at Speed Inc. for $3499, and a forged rod/piston/stock crank 355 for $2799. I shot them an email on it, but thought I would get your opinion too. Linky These seem to be the BEST thing I've found so far. Edit: LS1 speed have a 4 week wait right now, which may work out good.
I also found the following:
Revolutionary Performance "Budget" 383
Golen Short Blocks Specifically speaking, the $3199 fully forged 383.
All of these seem to fit into my budget, some barely (read Speed Inc.). Actually, they all put me a bit over, but they're ready to go.
What else would I be needing to get rolling again??
