Opps!
I did the same thing when swapping my 89 Celica motor. I just laid the harness out, and let the injector ends fall where they wanted to. Since they've been in the car for a few years, the wires will have a "memory" if you will. It worked for me. Good luck.
Strange, I have a 94 and mine are factory marked. Look close on all sides, you may be suprised
Sean
BTW, factory plugs wires were marked too, but the OEM replacements were not
Sean
Sean
Sean
There should be a number on the plug for the 94 and up sequential injection engines. I have never seen one that didn't have the large white number on each connector. Its on the "outside" of the plug, opposite side from where the "PED..." markings are. Are you sure the number you took to be a "9" isn't actually a "6"
93Z286Speed:
Interesting that you marked yours on the 93... the batch fire injection means it doesn't matter which plug is on which injector. .
93Z286Speed:
Originally posted by Injuneer
93Z286Speed:
93Z286Speed:
Boy dont i feel like an idiot
i didnt know that at all good to know
hehe thanks
