Opti delete
#46
Your existing throttle body will work just fine.
Only if you want to use a MAF sensor. The LS1 PCM can run in speed density mode. MAF sensor is not included and not required.
No, you don't need a new air intake to use the LS1 PCM.
These additional prices you're referring to are unrelated/unnecessary to swapping to the LS1 PCM.
There is a key to hold the crank timing sprocket. You simply have to install a 96-97 crank key to hold the reluctor in place.
Will it need a MAF sensor?
a new air lid with filter, is that included?
It does sound good but all these additional pieces---
the '93 does not have a crank shaft key on the ballancer hub, not sure about the crank gear though.
#50
Re: Opti delete
I'm pretty sure that the LT1 and LS1 MAF sensors were similar, to the extent that GM now has a single, less expensive part # that is a replacement for both the LT1 and LS1.
Nayr
03-03-2023 08:34 PM
tdigger9899
09-07-2015 10:56 AM
