Opti Harness
Opti Harness
I just wanted to make sure that the electrical harnesses are the same for all LT1's, is this so? And what about the bolts that hold it to the block/timing cover, are they the same also?
2 styles of opti harnesses, the 93 - 94 and the 95 - 97. One is longer than the other (connector length that plugs into the opti).
From Shoebox's site:
1993-1994 optispark (non-vented)
electrical harness 12106559 $55.19
1995-1997 optispark (vented)
electrical harness 12130319 $67.70
If you need a new one, here's a link to a cheaper source: http://www.casperselectronics.com/Me...Category_Code=
