Opti Keeps EXPLODING =/
#16
Originally posted by InjectedSS
wait your sayin to RULE THIS OUT as being the problem? or do u mean i should definately look into this as being the cause? also im running the ED timing chain so i guess we couldnt compare out numbers like that...
Yeah, better to measure total dowel length. Mine was .650", but it could have been a little longer and been ok.
#17
Certainly agree.. if that dowell is too long it will put too much force on that high tech plastic rotor.. cam end play may be in the mix also.. rule out the most probably then scratch yer head if that isnt it..
#18
Originally posted by shoebox
I'm saying, do what you have to do to prove to yourself that the dowel is not the problem. Most everyone's "exploding opti" condition has been caused by the dowel.
#19
just had to update this thread! turns out the problem WAS indeed the cam dowel! after like 4 opti's and two grinding sessions it's finally grinded down to where it doesn't hit and ive been running strong for about 2 months now thanks guys
#21
... a resurrected post.
This will help when someone uses the search. Glad you posted back.
people need to learn how to play the game
