opti not lining up
opti not lining up
Have tried for 3 hours to line up this new opti and it just won’t go on. Tried taking the cap off and moving the rotor to try to line it up and it won’t go. Tried doing the same with the old one and it won’t go on either. Really trying not to force it on. Any tips or tricks? Not a lot of info out there on this problem.
There is also a new opti seal.
Re: opti not lining up
Shoebox has a method, referencing TDC. Scroll down in his cam install procedure, under “Oil Pan Diagram”:
4th Gen LT1 F-body Cam Install
http://shbox.com/1/opti_back.jpg
Did this involve a cam change, and possibly the result of the dowel pin being too long?
windsma
10-25-2007 11:27 PM
