opti/plugs and plug wire?
Alright is the drivers side 1357 or 2468?? or is that switched also is the opti go from low numbers on the bottom or is it high numbers on the bottom? If this makes no sense post so and i will explain better.
Shoebox has a good drawing which is the same as in my Chiltons manual. Fortunately I memorized the sequence when I did plugs and wires last week.
Drivers top-bottom: 5-3-7-1
Passanger top-bottom: 4-6-8-2
The numbers are also on the opti itself.
Darth_tsunami
V6 Tech
09-18-2015 01:57 AM
grabbem88
03-18-2015 01:25 PM
