opti problems
Re: opti problems
When my cap/rotor went out I had a slight missfire throughout the entire rpm band. Sometime it can be really bad and sometime not even noticeable, mine resembled a bad batch of gas. Turned out that #8 had little to no spark at all Goodluck!
Re: opti problems
When my opti gave up the ghost, it started out as a stumble in the low RPM's, but was still rock solid above around 2 grand. It then progressively broadened throughout the operating range of the engine.
If you put it on a scanner, it'll tell you what code it is, i dont' have it on the top of my head. you can also search for DTC's for your vehicle on the 'net or a book.
10-31-2016 11:09 AM
grabbem88
03-18-2015 01:25 PM
Alex Barnes
01-24-2015 10:21 PM
