opti replaced, but weird things going on
I had to replace my opti (and waterpump as it leaking onto the opti was why it failed in the first place) and now if my MSD box isn't hooked up it will not start, and if I start it and then disconnect the MSD the engine dies. I followed the MSD wiring schematic fully and used the MSD to GM single connector harness. is the wiring schematic wrong? or is something else in my ignition dieing?
Re: opti replaced, but weird things going on
You're leaving the MSD box inserted in the ignition circuit, using the MSD wiring harness, and pulling the power to the MSD box. You're not removing the MSD harness and reconnecting the stock wiring? Sounds logical that it would not start. Or did I misunderstand what you are doing?
10-31-2016 11:09 AM
Dan_the_ManZ28
02-21-2015 02:01 PM
Hal Fisher
09-14-2002 09:36 PM
