opti spark on gen 1 sb
There are people who have put the optical sensor in a standard distributor of some sort. There is an outfit that converts the LT1 intake to bolt to Gen 1 heads, changing the location of two bolt holes, altering the bolt bearing surfaces to match the bolt angles of the Gen 1 heads, and adding the coolant nipples that the Gen 1 heads require. They will also drill the hole for a distributor.
grabbem88
03-18-2015 01:25 PM
