View Poll Results: What will you get to replace your dead OPTISPARK?
GM OPTISPARK $235.00
39
29.55%
MSD OPTISPARK $500.00
39
29.55%
Dyanaspark OPTISPARK $600.00
5.30%
Delteq system $695.00
31
23.48%
LTCC system $700.00+
21
15.91%
Multiple Choice Poll. Voters: 132. You may not vote on this poll
OPTISPARK replacement...What will you get next time: Delteq, MSD, GM....
Old 07-08-2006, 11:05 PM
  #61
quickmedic1's Avatar
Re: OPTISPARK replacement...What will you get next time: Delteq, MSD, GM....
Well I got the opti back and it is said to be working fine.
I changed the plugs out with new NGK TR6s gapped at .35
Accell 300+ wires were checked and no problems found. Resistance ok. No leaks of spark during bench testing with a coil.
Drove the car and ran great. Lots of power and no miss. Now after almost 100 miles car is getting sluggish again and starting to feel a miss again. I will pull the plugs again to check them. The first set was carbon fouled after 150 miles. I have a feeling I am going to find fouled plugs again. If so now what?
My combo is a 383 with a d1sc at 10 psi boost. Dynateck optispark,msd 6btm ignition, msd blaster coil, ngk tr6 plugs at .35
quickmedic1 is offline
Old 07-08-2006, 11:12 PM
  #62
Honda Hunter's Avatar
I canged the plugs out with new NGK TR6s gapped at .35
Glad you got yours back. Ive been waiting a while now Good luck and I hope you work out the bugs.
Honda Hunter is offline
Old 07-09-2006, 12:23 AM
  #63
You too bud. Any time frame on your stuff?
Old 07-09-2006, 12:49 AM
  #64
Hopefully sometime next week. I hope it last. Next time around I'm going LTCC.
Old 07-09-2006, 01:19 AM
  #65
wrd1972's Avatar
Originally Posted by Gripenfelter
I went LTCC with LS2 coils but it didn't cost me anywhere near $700.
I paid $170 for the coils and brackets and $399 for the LTCC
Do you have any pics of your setup?
BTW that is some seriously kick *** exhaust on your ride.
wrd1972 is offline
Old 07-09-2006, 01:28 AM
  #66
wrd1972's Avatar
Originally Posted by Injuneer
Custom.
With an aftermarket ECU, you can eliminate the Opti and rely on a crank position signal, but you lose the ability to run sequential injection, and you are limited to the "waste spark" system that the Delteq uses.
Is waste spark anything to be concerned with, I understand that it means the plug will fir on the exhaust stroke?
Does it wear out plugs faster?
wrd1972 is offline
  #67
OneFlyn95z28's Avatar
MSD OPTI and a Delteq with full MSD ignition
BTW quick med lean out your fuel at Idle
OH yeah "MSD test car"
OneFlyn95z28 is offline
Old 07-09-2006, 01:30 AM
  #68
wrd1972's Avatar
Thats some big bucks man. I know I would be pissed if I still had that damn stumble after all that.
wrd1972 is offline
Jeff1904
06-05-2016 05:00 PM
football4life
10-04-2015 07:48 AM
colts0455
09-27-2015 01:07 PM
Z Power
09-19-2015 11:19 PM
tommalcolm
09-11-2015 03:39 PM
Quick Reply: OPTISPARK replacement...What will you get next time: Delteq, MSD, GM....
