Optispark? Ugh, I hate typing that...
Old 01-29-2013 | 12:15 PM
cody96ss's Avatar
Angry Optispark? Ugh, I hate typing that...
Drove my 96 SS to work Tuesday, parked it at 745am. Went to leave work at 515pm and no start. Cranks, but no start.
No spark from coil.
New ICM
New Coil
No movement from tach, no RPM reading on scan tool.
Any ideas? I just replaced Opti-Spark 6 months ago...not looking forward to doing it again, but that is the answer I'm stuck on.
Old 01-29-2013 | 01:05 PM
javi805's Avatar
Re: Optispark? Ugh, I hate typing that...
is it giving you a code??? most likely it will be your opti i just changed mine a few days ago. go on youtube and type in optispark diagnosis. its an old video but very helpfull.. by the way whatbrand opti do u currently have???
Old 01-29-2013 | 04:18 PM
bw_hunter's Avatar
Please use the sticky at the top of the page to do a diagnosis on the OPTI and don't just change it out. The first thing to check is the short harness pluggin into the opti...corrosion in there is a possibility.
Old 01-29-2013 | 06:59 PM
If the tach is not responding, it MIGHT be pointing to a problem with the optical cam position sensor. Or the harness, as Bruce pointed out. If there is a problem, it would set codes. You indicate you have a scanner - are you seeing any codes?
What brand Opti did you install? The cheap Chinese ripoffs from ebay often don't last 6 months.
Old 02-23-2013 | 11:07 AM
cody96ss's Avatar
No codes relating to this problem... EGR, O2 sensor reading high (no cats), etc... Your computer won't send codes until it is ran. If you clear your codes, unplug an O2 sensor, and never start the car, it won't throw an O2 sensor code. Since it never started after I was parked, it didn't get a chance to throw a code. It was running like a charm until I parked it. 9 hours later, no start. I installed an ACCELL brand optispark. Turns out it was a year ago, but regardless, too soon.
Old 02-23-2013 | 12:27 PM
If it's the Opti cam position sensor it will set the codes as soon as you try and start it.
Hal Fisher
09-30-2015 09:03 PM
CARiD
09-30-2015 05:44 AM
surreybrad
09-29-2015 09:00 PM
colts0455
09-27-2015 01:07 PM
autoxr166
09-25-2015 04:21 PM
Quick Reply: Optispark? Ugh, I hate typing that...
