ovc wire looms
are the wire separators mounted to anything , could i see more pics ?
how much did the wires cost are those unaversail msd wire kit ?
The wires and separators I purchased from a local speed shop for about $100. It is a specific LT1 Kit, but all the wires you have to cut and terminate yourself.
The separators aren't mounted to anything, literally I'm using them to keep everything organized. However, I zip-tied them all over to keep them in place while cruising.
I am also using the Taylor High Temp Silicone Heat Sleeves.
What more pictures do you need? It is extremely straight forward. The driver's side I only have the plug wires for the last two cylinders going up and over, it was easiest to run the first two straight underneath because it'd keep them further away from the header primaries.
danielbmx
08-27-2002 11:11 PM
Wilson
07-21-2002 05:08 PM
