Overheating, whining under hood, no heat?
If you think about it, the water pump not working will cause the car to overheat. The coolant can't go through the heater core since it not circulating correctly and thus heater blows cold. The bad whining noise can be from the water pump being bad. Its looks like 3 strikes and your out in the garage changing it. I would not drive it at all if thats the case since you can cause serious damage to the motor. I know my 79z has a weep hole and will whine and drip coolant whens its going out. I assume the lt1's are the same.
Henson071
12-30-2015 09:55 PM
NewsBot
08-03-2015 02:40 PM
