Oxygen simulators
Old 01-19-2004 | 10:26 PM
matts_z28's Avatar
Oxygen simulators
I am having problems with my SES light coming on. The computer is saying bank 1 is too rich. I took it to the shop and they replaced both oxygen sensors before the converter. The light went away for a couple of days. It came back on so I took it back to the shop and now they say the oxygen sensor after the converter is bad. My cats are gutted. So I was told I should buy some O2 simulators to cheat the computer and the light would then stay off. I was wondering if anybody else uses or heard of these simulators and do they work. Thanks for the help.
Old 01-19-2004 | 10:30 PM
AsianSensation's Avatar
O2 simms only work for OBD2 and post cat only. Can't use it for the pre cat O2 sensors. They adjust the fuel trim.
kmook's Avatar
Advanced Tech Moderator
I used them and they worked fine for me. The other option is to not buy them and just have them programed out in the pcm/ecu/computer whatever you want to call it
Old 01-19-2004 | 10:33 PM
matts_z28's Avatar
The guy I bought the car from had that code into the computer. But somehow it is not reading it now. How does that happen?
Old 01-19-2004 | 10:47 PM
stereomandan's Avatar
It's cheaper to have them programmed out.
$75 from www.madz28.com
plus you can get some other goodies included for that $75.
Dan
quicksilver97ta
05-05-2021 08:41 PM
Pwilson59
09-03-2015 09:47 PM
lbrowne
04-22-2003 09:02 PM
KillinFormula
02-28-2003 10:15 PM
busta9876
06-28-2002 03:22 PM
Quick Reply: Oxygen simulators
