P0300 everything works fine
my 97 SS keeps throwing the same p0300 code. It seems very random and i cant detect any pinging or rough idle. Car seems healthy(enough to handle most near stock Stangs and imports in my area) and even gets 25-27mpg on the interstate. Gonna finally crawl under it and check all the wires(hopefully a loose plug wire). Plugs and Opit are under 10k and wires have about 30-35k.
Any other suggestions? Maybe run some Seafoam in the tank?
Can also be caused by problems with the crank position sensor, driving on extremely rough roads, or an aggressive camshaft. Are you running an aftermarket cam? Signature with "mods" would be helpful.
Rino1313
07-18-2002 05:16 PM
