P1153 code and speedometer needle bouncing when braking
My car a 1996 base Camaro recently threw a P1153 code suggesting an O2 sensor (bank 2 sensor 1) is either bad, or detected something.
Simultaneously, the speedometer needle started jumping or wiggling really, when I brake, or even turn on the blinkers, suggesting an electrical problem.
I recently replaced the compressor in this car. It required removing the engine ground connector. I believe the connector is tight, but should I try another ground wire to be sure? Could I have damaged a wire or sensor? Any suggestions appreciated.
Pete
Pete
Re: P1153 code and speedometer needle bouncing when braking
I cleared the code and so far there have been no more codes thrown. But my speedometer needle still wobbles rapidly (<1sec) when I hit the brakes. Is this a grounding problem? I've searched but can't find anything.
Thanks,
Pete
Thanks,
Pete
jj_burchiel
03-21-2015 12:51 AM
07-04-2005 05:00 PM
Darth Xed
13
07-22-2002 12:45 PM
