P1351 Code Help Needed! Thanks
Old 04-26-2007 | 09:13 PM
  #31
Have you checked out the coil wire to the opti? Still getting trouble codes?
Old 04-26-2007 | 09:44 PM
  #32
Mike96z's Avatar
Still got 1351 I think, I may be wrong but the engine light hasnt went off but ill check the codes tommorow. Coil wire is good, it was arching before to the coil when I had a bad coil but this time I put a zip tie around the wire where it attches to the coil so it wont slip off. I still am thinking optical sensor in opti.
Thanks for responding so fast to the thread, really appreciate the help.
Old 04-30-2007 | 09:23 PM
  #33
Mike96z's Avatar
Well got a brand new harness for the opti, and the crank sensor. Than I exchanged the optical side of the opti for a new one. So far no problems out of the car besides an oil leak, but well see what happens once I get it out in the heat and on the highway. Ill keep it posted.
Old 05-02-2007 | 06:58 AM
  #34
Mike96z's Avatar
YES! that fixed it. Thanks again for all the help. The optispark harness was really messed up bad and I think the terminals were touching inside where it connects to the optical sensor, but now all is good.
Old 05-06-2007 | 02:48 AM
  #35
Mike96z's Avatar
NVM! Still doing the same thing.
Parts Wanted
03-17-2015 11:24 PM
HectorM52
Parts Wanted
02-11-2015 09:33 AM
Deadbolt24
01-19-2015 01:29 PM
NED4SPD
09-16-2002 10:45 PM
mjcent922
07-27-2002 12:42 PM
Quick Reply: P1351 Code Help Needed! Thanks
