PAC Beehives on LT1
I would make sure those are the springs you want for your application and pressures you are looking for, I have them on my car, and its the second set, and I am still having problems, some people say I don't have enough spring some say its the PR lenght, orthers ignition so I am still lost.......be careful.......
there are tons of people on here running those with no problems, your problem is seprate so do not hijack his thread
you can re-use your lifters or the LS7 lifters are a nice replacement
sorry. i used 1.6 pro mag with 7/16 studs and arp studs, trickflow guideplates and trickflow chromolly pushrods
Comp 1305-16 rockers
Arp 134-7103 studs
Trick Flow 30400623-8 guide plates
you will need to measure your pushrod lenght and order according to that, you should be at a 7.200 and i would use the trick flow because they are alot cheaper but make sure they are chromolly
Arp 134-7103 studs
