Pacesetter Guys Inside!!
Old 01-30-2005 | 07:21 PM
Z28Horn's Avatar
Ive just installed my set of pacesetter LT's last night, it was a breeze, anyway im having some problems w/ my matching pace setter y-pipe, it is the y pipe w/ no cats, on my drivers side, i cant get the y pipe to slide onto the collector of the header, im waiting for my buddy right now but i was wondering if i can get that ypipe on w/ out unbolting my header, could i gently pry the collector down a little, hopefully you guys can help me with this one, thanks.
Zach
__________________
Alcohol, the cause and solution to all of lifes problems.
1996 Camaro Z28 195,000 mi.
K&n, Tb bypass, ported and polished maf, Trick flow elbow, Pacesetter Longtubes, 3" offroad y-pipe, strut tower brace, LCA's,Magnaflow catback, soon to have 3:73 gears and stall.
Z28Horn
View Public Profile
Send a private message to Z28Horn
Send email to Z28Horn
Find More Posts by Z28Horn
Add Z28Horn to Your Buddy List
Today, 07:56 PM #2
StickMaster
Posts: 183 Re: Pacesetter guys inside!!
I didnt have much of a problem with the Y-pipe (3 peices right?). Is your drivers side header hitting anything and not really bolted up right? Its close to the steering thing.
StickMaster
View Public Profile
Send a private message to StickMaster
Send email to StickMaster
Find More Posts by StickMaster
Add StickMaster to Your Buddy List
Today, 08:01 PM #3
Z28Horn
Posts: 19 Re: Pacesetter guys inside!!
can you even bolt the header in the wrong way?? it is the three piece y-pipe, im getting real frustrated w/ this pipe, i havent been out there to try it more but i hope you cant bolt it in wrong.
Zach
__________________
Old 01-30-2005 | 07:28 PM
Birdman7389's Avatar
Re: Pacesetter Guys Inside!!
you can try to bend the collector down a little, or just wedge the y pipe on there. I wrestled with mine for a few minutes and it slid on.... I wish it was the flange style though.
Old 01-30-2005 | 07:54 PM
Tibbys96Z's Avatar
I had to pull the collector down using the y-pipe.
WildRidez
03-27-2015 09:22 AM
Magenta_Hearts
03-25-2015 11:24 AM
carl.froehlich
03-13-2015 01:38 AM
Red97LT1
08-07-2002 06:45 PM
Quick Reply: Pacesetter Guys Inside!!
