Part number for Evap Purge Solenoid hard line?
I have searched but can not find. I need the number for the hard line that runs from the solenoid to the evap can with the fuel lines. Can anyone provide? For a 94 LT1. I need the number for the U shaped portion that runs around the throttle body.
Re: Part number for Evap Purge Solenoid hard line?
Thanks Shoebox. I checked your site but did not see this diagram. Good idea - I'll see if somebody has one in the parts wanted section.
It turns out the 97 is slightly different. The line is shorter. I think there is an evap vacuum sensor on the 97 that I don't have on the 94. I know I could make it work but I am trying to keep it original if I can. Thanks anyway.
