Part Number help please
First off, THANK YOU SHOEBOX for your web site! I was able to very easily find the part number the vacuum check valve that control the vents. Now I need the part number a light bulb. On the front right turn light (yellow) there is one light that comes on with the head lights and then there is the turn light, right? Or is it just one? Anyway, when I turn on my head lights/running lights that yellow light does not come on but it still works as a turn signal. Two yellow light up front, one inside and one outside. I need the inside light that is also in the turn light area. I would appreciate it if someone could give me that part number please.
My wife has to go pick these up for me since I have to work a lot this week. She is NOT a car person and will probably not get it right unless I give her part numbers. Even a better chance of not messing up if I give her part numbers with pictures. Half the time its not her fault, the parts counter guy gives her the wrong part but she doesn't know any better.
Thanks guys.
Thanks guys.
Yeah, I could if I could get there before they closed but since the wife was going to the GM dealer anyways.............2 birds one stone or something.
I have move about 10 ton of rock with a wheel barrow before it rains. The last rain (6 inches in one day) flooded out my crawlspace and I put in a drain pipe and have to cover it up with rock ASAP.
GM PART # 9441855 for the park lamp/turn signal bulb. It should be a #2397 bulb if you get one at the auto parts store. This bulb is specific to the 1993. 1994 and up use a different bulb.
Brandon Wittmer
12-07-2014 12:15 PM
