Part #'s for wiper blades and Wheel Speed sensor
Hey guys, I need to a new RightFront speed sensor and need a part number for that(dealer said I was throwing that code, and my ABS light keeps coming on).
Also I want some new wiper blades(the metal part as well, not just the insert) because mine are losing some paint- I have a list of part numbers for those but there are two, 22121694 and 12481132, which ones are right?
Thanks a lot for the help
You haven't downloaded the parts book?
You must buy a whole wheel hub for the front. The ABS sensor is part of it and not sold separately. Cost $120+ at your local auto parts store.
You can paint your blades with some Krylon satin black (or was it wrought iron black?) and they will look nice.
I sure did Couldnt find that sensor though, and now I know why. The wierd part is that Autozone quoted me a price for the sensor, so is it actually removable or were they just looking at the wrong thing? Buying a whole new hub would suck- is there anything else that could throw that code? ("RF speed sensor")
As for the wiper blades, I want GM replacements because none of the aftermarket ones I have looked at work properly- I guess I can try painting them though, I had considered it before.
Wiper blades are in Group 10. I think they are kinda pricey.
Thanks shoebox, I cant figure out where this item 19 comes into play though!?
As for the wipers, I found them in the catalog- but one is labeled "F" like most other parts and the other is "FP", gmpartsdirect has the same price for both but I'd like to know what the difference is.
There was someone on the board that went through this with the wipers and I think it ended up the ones that had the FP usage. I think he actually went to the dealer and compared them. You might try a search to see if you can find the thread about it. I looked a little, but did not find it.
Ok, thanks- I think Ill try the FP's, they do say 24" while the other one does not, so its a safer bet.
As for the low coolant sensor, I still dont get where that comes in! Are you saying it can be responsible for throwing the EGR code?
Are you sure AZ was not referring to a rear ABS sensor.
Oh, and now you are saying EGR. Did you mean ABS.
As for the ABS code, make sure none of the ABS sensor wiring is near any spark plug wires.
I got wiper blade replacements that work perfect from Discount Auto - including the metal blade. The brand name was actually OEM or something similar and they are an exact match, and cheaper than genuine GM.
07-04-2005 05:00 PM
