Part # for Thicker intake gaskets?
Does this even exist? I have new Stock GM and oil seeps past the bottom, so the car smokes. Anyone heard of a thicker gasket I can use? With the heads block and intake all milled, the intake doesn't seal right. Any ideas?
Re: Part # for Thicker intake gaskets?
is it leaking between the intake and the heads? or the front and rear of the motor? If it is just the front and rear of the motor I would just clean the old gunk off and put new RTV sealant or whatever it is there. You shouldn't need "thicker" intake gaskets if everything is stock
shouldnt... good luck though
10-31-2016 11:09 AM
