Parts required for cam swap
Old 12-08-2008, 09:10 PM
Malice 1's Avatar
I had a lifter come apart in my LT1. Since I have to pull the intake off anyways to get to the lifter, I think I might as well stab in my LT4 hotcam.
Help me ensure I get all the proper parts for my swap.
Front timing gasket set:
-timing cover gasket
-water pump gaskets
-front main seal
Intake gasket set:
-intake gaskets
-throttle body gasket
Pushrods:
help me pick a set of good hardened pushrods. Can someone provide me a link from summit or a reputable sponsor? I'm having trouble with summit's search funtion right now.
Lifters:
Since I had one explode on me, I might as well replace them all. Can someone recommend/link me to a good lifter set?
Are there any other parts I'll need that I haven't listed? I've had alot of trouble the past couple months with an unreliable valvetrain. I'd really like to take my time, use high quality parts, and do this right the first time.
BTW, I already have lunati springs, 1.6rr's installed, and a hotcam in a box in my garage.
Malice 1 is offline
Old 12-09-2008, 09:47 AM
seawolf06's Avatar
You'll need RTV for the intake and it also works to keep the water pump gaskets on while you install it. I like the Copper High Temp, but Ultra Black works, too. Some others like The Right Stuff, but it's up to you.
You don't have to use assembly lube on the cam, but it's only a couple bucks and it couldn't hurt to put it on the bearing surfaces. Just some oil on the lobes is fine.
You'll also need everything for a full oil change. No matter what you do, dirt and grit will get in the motor. Once the motor runs for a minute after you're done, change the oil right away. There is no break in for a cam swap.
You need coolant. I went ahead and did a full flush when I did the cam swap. Prestone I think has both a flush and a kit to make it a little less messy.
Pushrods: I'd suggest getting chromemoly in 7.2". They are more expensive than the hardened ones, but are worth it.
http://thunderracing.com/catalog/?ac...vid=4&pcid=106
Lifters: Just get Crane stock replacements. You will probably get suggestions for LS7 lifters, but I haven't had any experience with them and stock replacements are fine for your application.
http://www.jegs.com/i/Crane/270/10530-16/10002/-1
or
http://thunderracing.com/catalog/?ac...vid=4&pcid=107
seawolf06 is offline
Old 12-09-2008, 11:40 AM
87bandit's Avatar
don't forget AC refridgerant unless you want to risk snapping the condesor line by bending it
I'd say hardened pushrods ($30 brand new from comp) or more than enough for a hotcammed car, it's not like he's going to be revving to moon and have .600+ lift
87bandit is offline
Old 12-09-2008, 11:43 AM
km9v's Avatar
Replace timing chain?
km9v is offline
Old 12-09-2008, 11:49 AM
87bandit's Avatar
^+1 those things love to get loose after some mileage and they're cheap as dirt so why not
87bandit is offline
Old 12-09-2008, 11:57 AM
seawolf06's Avatar
I completely forgot about that one. Also upgrade to ARP bolts where you can!
Old 12-09-2008, 12:17 PM
Muncie4sp's Avatar
LT4 ED timing kit
12370835
GM Lifters
12499225 set
Muncie4sp is offline
Old 12-09-2008, 02:36 PM
94Z28rag's Avatar
LS7 lifters. Save yourself $75.
94Z28rag is offline
Old 12-09-2008, 02:48 PM
ACE1252's Avatar
Be careful....things add up....here is what I spent.....
http://www.ace1252.com/Z28_CC503_Per...ce_Buildup.xls
ACE1252 is offline
Old 12-09-2008, 02:52 PM
seawolf06's Avatar
That is a LOT more than just a cam swap.
Old 12-09-2008, 04:54 PM
87bandit's Avatar
my cc503 swap was pretty cheap, around $600 or so tops, then again I bought alot of used things
87bandit is offline
Old 12-09-2008, 08:12 PM
Malice 1's Avatar
Originally Posted by Muncie4sp
LT4 ED timing kit
12370835
GM Lifters
12499225 set
I just looked up those lifters on gmpartsdirect, and they were only $108 for a set. Comp or GM lifters were $230, and advance autoparts had an el cheapo chinese set for $166.
Frankly, I wouldn't mind getting the LS7 lifters, due to their RPM capability and the LOW LOW price. WHat pushrods do I need with those? Aren't the stock pushrods for the LT1 7.05"? What p-rods do I need for the LS7 lifters?
Malice 1 is offline
Old 12-09-2008, 08:13 PM
seawolf06's Avatar
Stock lt1 pushrods are 7.2". I'm not sure if the LS7 lifter requires a different pushrod or not.
There are a lot of threads about them here. Try searching.
Old 12-09-2008, 09:08 PM
6SpdLT1Z's Avatar
They should require longer pushrods IIRC. Get the tool and check to be sure.
6SpdLT1Z is offline
Old 12-09-2008, 09:13 PM
Malice 1's Avatar
My car is sitting dormant with a blown lifter. I'm sharing a car with my wife right now.
I think I"m gonna call thunder tommorrow, and just have them set me up with a complete, fool proof, bolt in kit.
Shoebox's guide will be my bible.
Malice 1 is offline
Quick Reply: Parts required for cam swap
