Pcv valve ??
Pcv valve ??
The pcv on my 94z goes from the tb to the top of the valve cover on the pass side correct ? the hose that goes from the tb to the valve cover has a tear in it what it is called ?? since its not the pcv valve it self ? if u get a new pcv valve does the hose come with it ???
any part #'s or anything would also help
Re: Pcv valve ??
The PCV valve on your car is on the drivers side of the intake manifold. Look for a U-shaped hose and just pull on it, it should pop out. The hose going from the valve cover to the TB i'm pretty sure is just a vacuum line.
Re: Pcv valve ??
That hose is part of the PCV system. According to this thread it's #10128365 :
http://web.camaross.com/forums/showt...tube+passenger
I happened to be searching for this recently. On the vette, it's a hard plastic tube with a small rubber hose joining it to the TB, and that hose was split. I was able to just use a piece of generic vacuum hose.
14
08-11-2015 12:03 PM
96SilverRam
08-09-2015 04:15 PM
RX Speed Works
07-24-2015 02:25 PM
