people who's in mid to low 12's with a stock heads, inside please
can you guys please list me all the mods that you have done. i dont think i can install LT headers, need to pass smog test. i'm planning get the XE 224/230 can, or cc305 cam. do you think i can do this?? go to low 12's with stick heads?? thanks guys
Originally posted by xxsaint69x
stock heads, untuned CC306, street tires, time in the sig.
Marcin
Marcin
I know "Eddie94Z" has a beefed up trans, hot cam, FLP's, Vig 3600 stall i believe and the rest just simple bolt-ons and runs 12.2ish....Also not fair
stock heads, intake, bottom end. Hooker LT's, turbo 400, DFI and a lunati cam little, 222/232 .471/.500 112 lobe seb.
11.80 @ 113.
1.55 60'
Car would have went faster.
It went 11.91 leaving off idle of 900 rpms. With a 1.59 60'
Elevation was at 2700 ft.
55 percent humidity
and about 60 deg
Check out my site for more info
11.80 @ 113.
1.55 60'
55 percent humidity
and about 60 deg
