perfect cam set up..ideas
Old 05-03-2009 | 06:49 AM
felon_gt1's Avatar
Arrow perfect cam set up..ideas
hey there guys so im looking to cam my 94 z28 a4....and ive looked around here and there so many ideas u guys have but i want to know what a good cam would be for a daily driver that wants some more bang....i hear hotcam...but also here comp? and what rollers should i get and valve springs..ext.... give me a perfect cam set-up...? if u could pls be specific im kinda a newb with camaros....thanks guys
Old 05-03-2009 | 07:05 AM
Chevyguy358's Avatar
We will need to know what has been done to the car as is as well as your intentions for the car after the cam (i.e. DD, future modding) etc...
Old 05-03-2009 | 07:09 AM
felon_gt1's Avatar
just want a above average z...i have c.ai pacesetter headers and exhaust...after cam i plan to tune it and call it a day...i dont need to much done..unless u guys have any sugg....i do want to keep it a daily driver tho...
Old 05-03-2009 | 08:03 AM
95zsean's Avatar
Hot cam kit.... It's all there in the kit except the gaskets.
Old 05-03-2009 | 08:36 AM
OPies57's Avatar
hot cam is for girls who dont want a nice idle. cc306 cam 1.6 comp promagnum roller rockers, comp 26918 beehive springs with appropriate locks and retainers. i daily drove this setup with a 6 speed and pcmforless tuning for over a year constantly kicking the **** out of it. also it doesnt completely decimate your gas mileage.
Old 05-03-2009 | 09:25 AM
<Puck>'s Avatar
...and ETs like trash on stock cubes and unported heads
I would much rather run the 503 then the 306 for an off the shelf cam-only setup.
Old 05-03-2009 | 09:45 AM
Airbornec507's Avatar
For overall price considerations. Patriot Gold extreme kit from thunderracing and there is a guy right now selling a brand new cc503 in the for sale section you can pick up for much cheaper than comp or thunderracing will sell it to you for. Springs and cam if you get the cam on this site will run you about $500. He's also selling a GM 847 so between those two cams you can't go wrong. O and yes a GM847 is fine for a DD it's just a little on the wild side so if your looking for something less wild but the best of both worlds the CC503 has been proven to work great on stock LT1 heads in the past.
Old 05-03-2009 | 11:10 AM
96capricemgr's Avatar
The 230+ intake duration cams on stock shortblocks are for kids that like to say "mine is bigger than your's" they do NOT ET best.
Overcamming is one of the oldest and most enduring mistakes in hotrodding.
Old 05-03-2009 | 11:19 AM
^Not sure if your refering to the statement I have posted however; I have personnally driven a GM847 camed LT1 stock bottom end stock heads that had excellent street manners w/no cam surge on a 2800 stall A4. It trapped 89mph in the 1/8th and ran consistent 7.7xx times in the 1/8th with 1.8xx 60' times. So from those results and my own personnal experiance I post my input to the OP. With this being said I still recommend the CC503 for the OP and leave the GM847 decision completely up to him.
Old 05-03-2009 | 11:58 AM
<Puck>'s Avatar
847 and 306 both want a lot more then 2800 stalls. Even my 22x/23x .575 lift cam had a little bit of cam surge with a 3200 stall(with an amazing dyno tune), so I find having perfect manners with an 847 w/2800 stall a bit hard to believe.
Old 05-03-2009 | 02:11 PM
twcblackhand6970's Avatar
I got a 306
Old 05-03-2009 | 02:29 PM
JAKEJR's Avatar
DITTO!!
Jake
West Point ROCKS!
Old 05-03-2009 | 06:59 PM
matLT1's Avatar
I think the cc503 would be a good cam for what you are after.
Old 05-03-2009 | 07:14 PM
reamo04's Avatar
these guys come in here, telling you to get the biggest cam you can. They are a bunch of ninnies for the most part. You do not need a big cam to run well.
Look at a Lingenfelter 219/219 .560/.560 cam. it will outperform most of the big cam cars out there, give you a little lope, and great low end power for driving around. It will be a much more enjoyable car.
Old 05-03-2009 | 08:26 PM
JAKEJR's Avatar
Speaking of a single-pattern cam, Ron Isky, in an interview, said " A single-pattern cam will always make more torque; let me repeat that, a single-pattern cam will always make more torque".
Food for thought.
Jake
West Point ROCKS!
