pic of something broken on my LT1, what is it??
I was taking out my PCM to get it programmed, and I noticed a line that was broken off at the fitting. I possibly could have broken it when I was taking out the pcm since the line was in the way, not sure though. Anyway, here are 2 pictures of what is broken, can someone tell me what this is, and to fix it what do I need to buy exactly, or can i just epoxy it back together??
Thanks for any help.
Brian
http://home.comcast.net/~bhawalka/broken1.jpg
http://home.comcast.net/~bhawalka/broken2.jpg
Brian
Re: pic of something broken on my LT1, what is it??
Brian
Brian
That looks like a check valve. I'd remove it, go to the dealer and get a new one, can't be more then a few bucks. Then pull the broken part out of the 90* vaccum fitting and plug it back in.
its is a vacuum check valve - mine was broken also - controls where the heat/vent/ac will blow (feel, defrost, main vents) cost like $3 at autozone...
Yep. One line goes into the car for the HVAC controls, one goes to the intake manifold, and the other goes to the vacuum reserve canister on the passenger frame rail.
Ryan
Ryan
