Pickup tubes: 5/8" versus 3/4"
Is 3/4" necessary? Car is a 93 and it came with the 5/8"...just curious. Engine isn't gonna be a screaming 7k rpm monster or anything, just a cam only gm847.
And for the record, there are WAY too many different oil pumps to choose from!
Let me look around and see what i can find for you on it.
Did you already buy the cam?
For what your wanting a GM847 is a bad choice for you, that cam loves higher rpm and needs to breath threw a good set of heads, theres much better options for you that will still allow some actual low end power still.
After a TON of reading, it seems that Melling makes almost everyone's housing for their pumps. Which would mean they ALL suck!
Can I order a new one and put the parts in my stock housing?
