Pickup tubes: 5/8" versus 3/4"
Old 10-18-2007, 09:15 PM
  #16
marshall93z's Avatar
Alright. Thanks guys!
marshall93z is offline
Old 11-08-2007, 09:20 PM
  #17
My Iroc Z28's Avatar
What pump driveshaft are you guys using with the M-10555 Pump?
My Iroc Z28 is offline
Old 11-08-2007, 09:29 PM
  #18
speed_demon24's Avatar
My melling select pump came with a new shaft.
speed_demon24 is offline
Old 11-08-2007, 09:31 PM
  #19
did it happen to include a part number with the paperwork?
right now i have the bad design pump (M-55HV) Not by choice i'll deal with that later, And the IS-55E Driveshaft and im wondering if it will work with the M-10555 pump.
Old 11-09-2007, 10:44 AM
  #20
cehan's Avatar
Before I ordered my Melling Select HV pump, I called the Melling tech support line. The guy I spoke to suggested that I not use the drive shaft that comes with the model 10550 HV pump but to use their chrome moly drive shaft instead (P/N 12550), which I ordered at the same time. As I remember, it was something like $10-$12 from Summit.
cehan is offline
Old 11-09-2007, 01:49 PM
  #21
Thank you, Just contacted George there and he told me the samething. Now i will order a new pump/pickup & Driveshaft.
Old 11-09-2007, 01:56 PM
  #22
y5e06's Avatar
I used the 'regular' tube size canton version #20-020, I believe the 5/8".
Anyway, I have over 1500 road racing miles on the engine using 40 & 50 wt oils screaming around the track between 3500rpm & redline for laps on end. no problems what so ever. so, no, I don't think the 3/4" pickup is necessary
y5e06 is offline
Old 11-09-2007, 02:07 PM
  #23
Whats wrong with the shaft that comes with the oil pump?
Old 11-09-2007, 02:09 PM
  #24
Thanks for the input. Im also wondering if there is a noticeable difference from using a bigger inlet.
According to melling the best pump they have with the 25% Increased volume is the 10555 and that needs a 3/4'' Pickup so thats why i was switching from the 5/8ths to 3/4
Old 11-09-2007, 02:10 PM
  #25
George didn't say, All he said is that is the one they recommend to use with the Hv pump
Old 11-09-2007, 02:12 PM
  #26
WS6T3RROR's Avatar
I run a 5/8" pickup in my setup, no difference as far as i can tell.
WS6T3RROR is offline
Old 11-09-2007, 04:34 PM
  #27
Kevin Blown 95 TA's Avatar
Not sure which one comes with that pump, but some of them come with a plastic coupling which is considered a weak point.
Kevin Blown 95 TA is offline
Old 11-09-2007, 11:33 PM
  #28
The one that came with mine is all steel.
G-BODYT56
01-14-2022 11:14 PM
13qtr
10-28-2016 08:11 PM
Queens94z28
09-20-2015 08:45 PM
WPHIG2
08-27-2015 06:37 AM
Quick Reply: Pickup tubes: 5/8" versus 3/4"
