PISSED OFF!! 5th set of burnt plug wires!!
Old 07-26-2003, 10:08 PM
  #16
magius231's Avatar
when I asked about misfires most people indicated it wasn't really an issue anymore due to better wire design/shielding. Think of it this way, if they could crossfire that easily, the factory wires would be completely hosed, and they are running up against the block too!
magius231 is offline
Old 07-26-2003, 10:49 PM
  #17
bad95z28's Avatar
I will never run wires through the stock location again on an LT1 once I finally switched over to the otvc wiress. Best money spent in my opinion.
Michael
bad95z28 is offline
Old 07-27-2003, 12:34 PM
  #18
a_z28_vance's Avatar
Originally posted by simple
Taylor OTVC wires and looms with hooker longtubes, had them on the car for about 2 days running and absolutely no problems
zipties are your friend when it comes to ignition wires
Have the same thing set-up for the last 18 months and no burnt wires.
a_z28_vance is offline
Old 07-27-2003, 01:17 PM
  #19
Camaro_SS/R's Avatar
Taking your time to run and place the wires is key. Make sure to keep the wires off the headers. Definitely! use the Taylor Firesleeve, well spent $50 instead of 5 burnt wire sets plus installation. Get some wire separators and try running the wires behind the motor mount. Doing this with my LT and 8.5mm, I haven't burn a wire for almost a year.
Camaro_SS/R is offline
Old 07-27-2003, 01:56 PM
  #20
Black_Z28's Avatar
You guys that are routing the wires behind the motor mount, are you using the stock length wires? I did OVC and I don't like them. They're ugly. So, I'm going to go back to a stock location, or like stock location. I also need new wires. Where can you buy the Accel 9000 wires? Thanks.
Black_Z28 is offline
Old 07-27-2003, 02:52 PM
  #21
jim88iroc305's Avatar
Cool
for Accel Extreme 9000 Heat Reflective Ignition Wires
www.jegs.com
www.summitracing.com
www.skspeed.com
your local speed shop
make sure to give them year model make and engine size, they're year(s) specific
jim88iroc305 is offline
Old 07-27-2003, 09:49 PM
  #22
seanW's Avatar
The wire I keep burning is the #6 cyl. I'm going to take one of the longer plug wires from the old set and try to run them up and over the primaries. O and I use the Taylor heat sleeves on all my wires. # 6 is burning under the sleeves??? anyway I was really pissed off when I wrote this, and now I've calmed down a bit. Thanks for everyone's reply.
sean
seanW is offline
Old 07-27-2003, 10:00 PM
  #23
Black_Z28's Avatar
www.jegs.com
www.skspeed.com
Do you know the part number for the LT1? Thanks.
Forget it, I found them.
Alex Barnes
01-24-2015 10:21 PM
Jazsun
12-29-2014 12:14 PM
BIGCOWL-IMP
11-21-2014 09:40 AM
DubbyZ28Camaro
08-04-2002 12:53 PM
Quick Reply: PISSED OFF!! 5th set of burnt plug wires!!
