Pistons
Jegs has these JE forged pistons listed. Part number 532-170817 is an inverted dome that will come in around 9.2:1. That will be the closest off the shelf piston for your stated goal of 9.5. In addition, if you have your heads resurfaced, or run a thinner head gasket, that will bump your compression closer to 9.5.
gonzo275rltw
09-05-2015 06:26 PM
gonzo275rltw
09-05-2015 06:24 PM
