Pistons
#16
yea I've noticed they all like to use - or + numbers very liberally. Suppose it comes from looking at it from the pistons point of view or the heads point of view
So I used one I found on google then I noticed we had one here so I checked it out. both fall mid 11's. So I think I should be A-OK
Thanks for the help with this though. I was slightly confused... also why is that there is a different listing for gen II stuff when gen I works?
#18
#19
Just get the Mahle Power Packs for SBC and you will be good to go, IMO they are a great value for the money.
I'm running a .027 thick head gasket with the pistons .005 in the hole, the compression is a little above 12:1 and it runs on pump gas without detonation. So there is no need for popups/dome whatever.
Good luck with your build.
gonzo275rltw
09-05-2015 06:26 PM
gonzo275rltw
09-05-2015 06:24 PM
