Pistons, Left and Right
On single SBC/LT1 pistons they are listed as right and left. I'm looking for a #4 piston, and I believe I am looking for a left piston.. is that correct?
I'm thinking that it goes #8 left #6 right #4 left #2 right.
Can someone confirm?
LOL Thanks for the reply but this is exactly why I couldn't get an answer through any searches! I just keep pulling up that same info
I understand which side of the engine the pistons are on that's not what I am asking. My question is in regards to valve reliefs and what makes a piston a right or left since you've got two different pistons on each side of the engine. One pair of them, the intake valve relief is on the left, the other pair the intake valve relief is on the right. I need to know if #4 is a "left" piston or a "right" piston.
Sorry this wasn't clear, hopefully it is now.
While that is true of some pistons, it does matter for what I am looking for. As I stated, I need to replace the #4 in a full set of pistons. They are sold individually and are listed as right or left, two different part numbers. They are not all the same pistons.
http://i190.photobucket.com/albums/z.../rightleft.jpg
Catmaigne
07-14-2015 05:17 PM
