Please help!?! 1994 Z28
I need some help with my Z28
When I get up to drive it after it has been sitting for a day or so, Ill start the car up, it makes a popping noise and I have to rev the car up to about 2500k for a few minutes, otherwise it boggs down and will shut off.
BTW: This crap didn't start until I put some ''gunk'' on the engine and sprayed it off at the carwash...Idk if I got something wet or not
ALSO......
After driving for a little while...the temp gauge will red line (260) especially when I'm at a complete stop. The engine doesn't smoke, and I haven't seen a coolant leak...and the low coolant light is on, but when I fill it, it doesn't go off
If someone knows what the issue is, please let me know asap, and thanks in advance for your help!!!!
ALSO......
Re: Please help!?! 1994 Z28
Water might have got into the distributor/cap, It's common in the 94-95 lt1's for water to easily get into the opti-spark Distributor because its not sealed or vented to well and what water/moisture gets into it doesnt really get out of it.
Does the car idle/drive the same after it is warmed up?
When did your temp problem start? Before or after you washed the engine?
You may have to burp the cooling system with the 2 venting screws.
Try and put more info about the problem you have so more answers will be given.
After the car warms up, it doesn't bogg down like it does when you start it, it drives fine. The temp problem has been an ongoing problem, did not get any worse or any better when the engine was washed, and I have NO CLUE how to burp the cooling system....can anyone walk me through it?
It can be very expensive if you cant work on it your self. Parts can be $150 for the distributor and $175 for the cap and rotor from a place like autozone but these parts are cheap. you would need other minor parts also.
Hve some shop scan the car.
Here is the 2 venting screws to get the air out of the cooling system.
http://shbox.com/1/bleeders.jpg
what I would do Is remove the radiator cap and then loosen one of the screws up or remove it then add water to the radiator. when the water starts to come out tighten the screw back down. then do the same with the other one. then do it again after the next time you drive the car but not when it's hot. If that dont help the temp problem then you have another problem.
Read through here
http://shbox.com/1/4th_gen_tech2.html#radflush
Read through here
if u pay to get your opti changed it can be quite costly, the part if you get a delphi unit off ebay is 350-400 dollars, and labor is a bit intensive...i was quoted 1500 parts and labor...but i got the opti for 365 off ebay and had a couple friends help me out and it all worked out great. if you can do the work yourself...its not too too expensive..paying someone to have it done is a different story
That baloney about the early distributors being prone to water intrusion just isn't true. The venting was added to remove ozone and extend the life of the high voltage section.
However, a distributor cap is a tune up item and show be replaced on a regular basis. It sounds like yours is due if it gets wet and stumbles, then works better as it dries.
You need a scaN to tell you what is going on with the cooling. It could be as simple as air trapped in the system. Your owners manual tells you how to bleed the air out of the system.
opti swap isn't hard. Buy it and do it yourself. Get a GM opti.
Drain coolant
Remove water pump
Remove harmonic balancer
Remove opti
It's really that simple.
Reinstall opti
Reinstall harmonic balancer
Reinstall water pump with new gaskets
Fill coolant
Bleed coolant and you're done.
Drain coolant
Remove water pump
Remove opti
Reinstall opti
Fill coolant
+1 easier and cheaper than an opti. if it runs fine once it warms up it's possible your coolant temp sensor is screwed up. take it to a shop or something and have someone look at the car, just make sure they know how to work on an LT1.
lesson hard learned. when cleaning the engine bay, or doing anything to these lt1s you need to be extremly careful about the craptispark, these are prone to going out with water. i had mine give me a little truble backflushing the heater core (a tiny bit of coolant got on the opti) after about 5 minutes of misfire it was fine (water dried) but this is not always the case, and im sure it hurt the life expectancy of my opti. On the plus side i can survive these Missouri winters with hot heat.
94z28jbw
09-08-2002 03:22 PM
