plugged cat
plugged cat
Ok I need some help on this one.My cat converter is partially plugged,and I have no idea wheter to get a universal fit high flow converter or a direct fit replacement.I know a direct fit is probably going to cost me 300 dollars,but Im also hesitent on getting a universal because im purchasing a magnaflow catback,and the last thing I want to do is cut the flange off a brand new catback,so does anyone know where I can get a cheap direct fit replacement?Any help would be greatly appreciated.If I do get a universal fit what size would I need?
Re: plugged cat
I would measure your existing converter: Inlet ID and OD, outlet ID Od and the width, length, height and any flanges that you might have then take them measurements to the parts store and let them match it up with the closed fit then you decide if you like 100-150 versus 300 bucks.
Re: plugged cat
Well I think Im just going to get a high flow like magnaflow,because I cant affor to buy a $300 dollar converter and a $300 magnaflow catback.Nobody remembers what size they had to get when they bought there aftermarket cat?
jasonduaine
04-01-2015 08:09 PM
armedtrigger
02-24-2015 08:30 PM
12-01-2014 08:08 AM
