plugs
It's easier to just pull the engine.
I know I have to pull the starter (or at least unbolt it and tilt it out of the way) to reach #8. Also, I think having the alternator and the rear brackets (the black arms) out of the way helps. Mine was already removed because I did my plugs when I had the intake manifold off last year to fix the rear leak...
I think the driver's side is alright without really removing anything, but IIRC I also got #7 from underneath.
I'm glad I've only had to do that job once, though now I'm in the middle of changing the wires, which is about as bad... Good luck!
The original poster, "steven92f" has not been active on the site since 3/13/10. You might want to send him an e-mail.
Or search for related threads on changing plugs - how to. There are many threads, and one in the past couple weeks.
14
08-11-2015 12:03 PM
zajones
07-30-2015 02:18 PM
