Plugs and Wires
Plugs and Wires
I wanted to know what the best combo would be, I wanted to go with Taylor Thunder volt 10.4mm wires and NGK plugs. Any suggestions or would this be a good combo? Thanx for the imput!!!
Originally posted by hozb817
Loadre, I noticed a Mallory decal under your hood, do you have a Mallory ignition? If you do how is it working for you? Would you recommend it?? Thanx !!
I have used the Accel 9000s and the stock type ACs in my stroker for 8 years with no issues...I do change plugs/wires every 2 years as scheduled maintenance...You may want to check out Thunderracing for their Taylor/Made-for-you over the valve covers wire & loom combo...$99.00 with a crimper...seems like a great idea. You know how muck of a pain it is to route the wires from underneath...I'm gonna check it out myself...I've seen other threads where people love the kit...
Re: wires & plugs
Originally posted by Mike383LT1
msd 8.5's and ngk tr6
As far as wires go, stock replacement is fine...
Taylor 8mm Spiros and NGK TR55s here. Great so far
Also routing your wires from underneath is time consuming. when you think you are done you find one or two wires are not where they are supposed to be (passenger side). I've a 95 twin cat and had to remove the Y pipe. Pain in the rear fer sure.
Marvin
charchri4
04-14-2015 06:40 PM
eanhl2004
04-04-2015 12:01 PM
