Poly Motor Mounts
Poly Motor Mounts
OK, I just did Jet-Hot LT's and Hooker Y-pipe, I have really tight clearance between the driver side flange and Ypipe and NOW I want to go polly motor mounts. How hard are these to change now that I have the headers in? I could've done those soooo easy when I was installing the headers, but stupid me.
Help?
Help?
Originally posted by Red_94Formula
the stock motor mounts collapse and sag. there will be sag def. putting in poly mounts will raise the motor slighlty.
dont know about longtubes yet
but with rksport headers, impossible i just removed the header again.
you will love the poly mounts, you know when you rev the engine your motor rock to one side.....with the new poly mounts the motor does NOT move in the engine bay, it rocks the car
(get a poly tranny mount while your at it)
jesse
jesse
www.bmrfabrication.com
7-508 - Polyurethane motor mount kit 1993-1997 LT1(both sides included) $59.95
rpm4lalo
08-03-2002 02:35 PM
