post any tip for LT1 owners
i thought it would be nice to post random tips about maintenance or anything else with these lt1's. we can help other lt1 owners out. i will get it started:
clean fuel filters help fuel economy and permance
thread lock works great for sealing drain bolts on the rearend and tranny
don't rely on a jack to hold a car up in the air
When taking out a manual transmission, make sure the clutch fork has been pulled out, and start the actual removal by removing the transmission from the bell-housing, then remove the bell housing from the engine.
Fullagar
Fullagar
dont pressure wash your engine bay
dont get into a "window race"
dont use slicks
dont use snythetic trans fluid
dont buy from racenet or SLP
dont buy aftermarket MAF on a stock car
get a trans cooler
dont get your wrench stuck in your TB
dont use regular 87 octane
dont brag about build quality
dont use slicks
get a trans cooler
If you got a convertible, DONT mess with the gaskets... it may leak a little but its better then getting your whole interior wet when you wash it. need to take mine to an upholstry shop soon cuz that happened to me today
Originally posted by rpm4lalo
Could you elaborate on this topic please?
When I changed the fluid for my T56, I replaced it with Mobil 1 synthetic fluid. What brand would you reccomend?
i dont know anything about the t-56 except that i have one laying around that i dnt know what to do with
big paper weight?
a4 you should use fords fluid-
this coming from a GM engineer who blows up 4L60E's for a living
the T56 uses a dexron fluid like the automatics, do not use standard gear oil
when working in your cars engine bay do as much as possible at one time to save yourself the hassle of having to get into the VERY tight working conditions more than once
