Power Loss After Worm Up?
If i let my car set and get ice cold it runs perfect, as soon as it gets to normal operating temp. the car falls flat on it face. Dose anyone know wha i going on it the camaro listed in my sig.
Get it scanned, if there are no codes, see if the garage scanning it can use their computer to data stream. If they can, watch the O2 sensors, they should constantly fluctuate between 100-900 mV. If one is slower than the other, is sticking at any one position, or has a limited range, your probly going to be looking at replacing them.
Since it only does it when it warms up, that means it is very possibly a sensor related issue. The computer for your car operates in open loop when cold, running off of set parameters in the PCM. Once it reaches operating temperature, it uses information from sensors (Such as the oxygen sensors in the exhaust) to adjust air/fuel and timing. This is called Closed Loop operation.
Hard to tell you anything else without getting codes scanned, or sensors data streamed.
